ArcGIS.Core.Data.Topology Namespace / TopologyRule Class / OriginClass Property
Example
    OriginClass Property (TopologyRule)
    Gets the name of the origin feature class to which this topology rule is assigned.
    Syntax
    Public ReadOnly Property OriginClass As String
    public string OriginClass {get;}
    Example
    Get topology rules
      static void GetTopologyRules()
        using (Geodatabase geodatabase = new Geodatabase(new FileGeodatabaseConnectionPath(new Uri(@"C:\TestData\GrandTeton.gdb"))))
        using (ArcGIS.Core.Data.Topology.Topology topology = geodatabase.OpenDataset<ArcGIS.Core.Data.Topology.Topology>("Backcountry_Topology"))
          using (TopologyDefinition topologyDefinition = topology.GetDefinition())
            IReadOnlyList<TopologyRule> rules = topologyDefinition.GetRules();
            Console.WriteLine($"There are {rules.Count} topology rules defined for the topology:");
            Console.WriteLine("ID \t Origin Class \t Origin Subtype \t Destination Class \t Destination Subtype \t Rule Type");
            foreach (TopologyRule rule in rules)
              Console.Write($"{rule.ID}");
              Console.Write(!String.IsNullOrEmpty(rule.OriginClass) ? $"\t{rule.OriginClass}" : "\t\"\"");
              Console.Write(rule.OriginSubtype != null ? $"\t{rule.OriginSubtype.GetName()}" : "\t\"\"");
              Console.Write(!String.IsNullOrEmpty(rule.DestinationClass) ? $"\t{rule.DestinationClass}" : "\t\"\"");
              Console.Write(rule.DestinationSubtype != null ? $"\t{rule.DestinationSubtype.GetName()}" : "\t\"\"");
              Console.Write($"\t{rule.RuleType}");
              Console.WriteLine();
    Requirements
