ArcGIS.Desktop.Mapping Namespace / Layer Class / CanGetZs Method
Example
    CanGetZs Method
    Determines whether the layer can be used as an elevation source to retrieve Z values for geometries. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function CanGetZs() As Boolean
    public bool CanGetZs()
    Return Value
    True if this layer can be used by the GetZs methods, False otherwise
    Exceptions
    ExceptionDescription
    Remarks
    Not all layers can be used as an elevation source. Typically TINs and some rasters are supported. Also some image service files that support non-binary levels of detail.
    Example
    Get Z values from a layer
        TinLayer tinLayer = map.GetLayersAsFlattenedList().OfType<TinLayer>().FirstOrDefault();
        //Note: This method must be called on the MCT
        MapPoint mapPoint = MapView.Active.Map.CalculateFullExtent().Center; //Any Map Point
        Polyline polyline = PolylineBuilderEx.CreatePolyline(mapView.Extent); //Any Polyline
        if (tinLayer.CanGetZs())
            // get z value for a mapPoint
            var zResult = tinLayer.GetZs(mapPoint);
            if (zResult.Status == SurfaceZsResultStatus.Ok)
                // cast to a mapPoint
                var mapPointZ = zResult.Geometry as MapPoint;
                var z = mapPointZ.Z;
            // get z values for a polyline
            zResult = tinLayer.GetZs(polyline);
                var polylineZ = zResult.Geometry as Polyline;
    Get Z values from a TIN Layer
      // Note: Needs QueuedTask to run
            // cast to a Polyline
    Requirements
    ArcGIS Pro version: 3.4 or higher.
