ArcGIS.Core.Geometry Namespace / Polygon Class / ExteriorRingCount Property
Example
    Gets the number of exterior rings in this polygon.
    Syntax
    Public ReadOnly Property ExteriorRingCount As Integer
    public int ExteriorRingCount {get;}
    Remarks
    An exterior ring is a part that is oriented clockwise.
    Example
    Get the exterior rings of a polygon - polygon.GetExteriorRing
      static void GetExteriorRings(Polygon inputPolygon)
        if (inputPolygon == null || inputPolygon.IsEmpty)
          return;
        // polygon part count
        int partCount = inputPolygon.PartCount;
        // polygon exterior ring count
        int numExtRings = inputPolygon.ExteriorRingCount;
        // get set of exterior rings for the polygon
        IList<Polygon> extRings = inputPolygon.GetExteriorRings();
        // test each part for "exterior ring"
        for (int idx = 0; idx < partCount; idx++)
          bool isExteriorRing = inputPolygon.IsExteriorRing(idx);
          var ring = inputPolygon.GetExteriorRing(idx);
    Requirements
