ArcGIS.Desktop.Mapping Namespace / Layer Class / GetZsAsync Method / GetZsAsync(Geometry) Method
the input geometry
    Obtains a geometry that is similar to the given input geometry, where some or all Z values are populated from the layer.
    Syntax
    Public Overloads Function GetZsAsync( _
       ByVal geometry As Geometry _
    ) As Task(Of SurfaceZsResult)
    public Task<SurfaceZsResult> GetZsAsync(
       Geometry geometry
    Parameters
    geometry
    the input geometry
    Return Value
    A result that contains a status, plus an output geometry only if the status is favorable.
    Exceptions
    ExceptionDescription
    The input geometry is null.
    Remarks
    If the layer has no data at a particular input geometry point, then the corresponding output geometry point Z will be set to the value specified in SurfaceZsMissingHandler.DefaultOutputZ.
    Use CanGetZsAsync to determine if the layer can be used as an elevation source before calling this function.
    Requirements
    ArcGIS Pro version: 3.4 or higher.
