ArcGIS.Desktop.Mapping Namespace / Layer Class / GetZsAsync Method / GetZsAsync(Double,Double) Method
The x-coordinate
The y-coordinate
    Obtains a point geometry with Z for the specified (x,y); where the Z value is populated from the layer.
    Syntax
    Public Overloads Function GetZsAsync( _
       ByVal x As Double, _
       ByVal y As Double _
    ) As Task(Of SurfaceZsResult)
    public Task<SurfaceZsResult> GetZsAsync(
       double x,
       double y
    Parameters
    x
    The x-coordinate
    y
    The y-coordinate
    Return Value
    A result that contains a status, plus an output geometry only if the status is favorable.
    Remarks
    If the layer has no data at a particular input geometry point, then the corresponding output geometry point Z will be set to the value specified in SurfaceZsMissingHandler.DefaultOutputZ.
    Use CanGetZsAsync to determine if the layer can be used as an elevation source before calling this function.
    Requirements
    ArcGIS Pro version: 3.4 or higher.
