ArcGIS.Desktop.Core.DeviceLocation Namespace / DeviceLocationService Class / Open Method
A DeviceLocationSource.
A DeviceLocationProperties.
Example
    Open Method (DeviceLocationService)
    Connects to a new device location source such as a GPS/GNSS device via a COM port. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Exceptions
    ExceptionDescription
    Value cannot be null: source
    DeviceLocationSource ComPort cannot be null
    Remarks
    At a minimum, a ComPort must be specified in the DeviceLocationSource parameter.
    Example
    var sp = new SerialPortDeviceLocationSource()
      ComPort = "COM4",
    await QueuedTask.Run(() =>
      DeviceLocationService.Instance.Open(sp);
    Requirements
