ArcGIS.Desktop.Mapping Namespace / RasterLayer Class / GetSurfaceValues Method
The point location.
    GetSurfaceValues Method (RasterLayer)
    Gets elevation, slope and aspect values from the surface at the specified xy location. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetSurfaceValues( _
       ByVal point As MapPoint _
    ) As SurfaceValues
    public SurfaceValues GetSurfaceValues(
       MapPoint point
    Parameters
    point
    The point location.
    Return Value
    Exceptions
    ExceptionDescription
    point is null or empty.
    An exception occurred within the GetSurfaceValues calculation.
    Remarks
    Bilinear interpolation is used to return the z value or elevation on the raster surface.
    GetSurfaceValues will handle differences in spatial reference between the input point and the surface. It will project (a copy of) the input point to match the surface for the sake of interpolation.
    Requirements
    ArcGIS Pro version: 3.4 or higher.
