public override MapPoint GetPositionAsMapPoint()
Public Overrides NotOverridable Function GetPositionAsMapPoint() As MapPoint
| Exception | Description |
| ArcGIS.Core.CalledOnWrongThreadException | This method or property must be called within the lambda passed to QueuedTask.Run |
SnapshotChangedEvent.Subscribe(args => _ = OnSnapshotChangedAsync(args));
/// Handles changes to a snapshot by processing the provided snapshot data.
async Task OnSnapshotChangedAsync(SnapshotChangedEventArgs args)
if (args == null)
return;
var snapshot = args.Snapshot as NMEASnapshot;
if (snapshot == null)
return;
var pt = await QueuedTask.Run(() => snapshot.GetPositionAsMapPoint());
if (pt?.IsEmpty ?? true)
return;
// access properties
var alt = snapshot.Altitude;
var dt = snapshot.DateTime;
var vdop = snapshot.VDOP;
var hdop = snapshot.HDOP;
// etc
//TODO: use the snapshot
