ArcGIS.Desktop.Core.DeviceLocation Namespace / NMEASnapshot Class / VDOP Property
Example
    VDOP Property
    Gets the vertical dilution of precision.
    Syntax
    public Nullable<double> VDOP {get;}
    Public ReadOnly Property VDOP As Nullable(Of Double)
    Example
    Subscribe to Location Snapshot event
      SnapshotChangedEvent.Subscribe(args => _ = OnSnapshotChangedAsync(args));
      /// Handles changes to a snapshot by processing the provided snapshot data.
      async Task OnSnapshotChangedAsync(SnapshotChangedEventArgs args)
        if (args == null)
          return;
        var snapshot = args.Snapshot as NMEASnapshot;
        if (snapshot == null)
          return;
        var pt = await QueuedTask.Run(() => snapshot.GetPositionAsMapPoint());
        if (pt?.IsEmpty ?? true)
          return;
        // access properties
        var alt = snapshot.Altitude;
        var dt = snapshot.DateTime;
        var vdop = snapshot.VDOP;
        var hdop = snapshot.HDOP;
        // etc
        //TODO: use the snapshot
    Requirements
