ArcGIS.Desktop.Core.DeviceLocation Namespace / SerialPortDeviceLocationSource Class
Members Example
    Represents a location device source such as GPS/GNSS device that is connected via a serial port.
    Object Model
    SerialPortDeviceLocationSource ClassSpatialReference Class
    Syntax
    Example
    Get Current Device Location Source and Properties
      // Check if a device is connected
      bool isConnected = DeviceLocationService.Instance.IsDeviceConnected();
      if (!isConnected)
        return; // no device connected
      // Get the current device location source
      var src = DeviceLocationService.Instance.GetSource();
      // Check if the source is a SerialPortDeviceLocationSource
      //Set values for the SerialPortDeviceLocationSource
      if (src is SerialPortDeviceLocationSource serialPortSrc)
        var port = serialPortSrc.ComPort;
        var antennaHeight = serialPortSrc.AntennaHeight;
        var dataBits = serialPortSrc.DataBits;
        var baudRate = serialPortSrc.BaudRate;
        var parity = serialPortSrc.Parity;
        var stopBits = serialPortSrc.StopBits;
        var sr = await QueuedTask.Run(() =>
          return serialPortSrc.GetSpatialReference();
      //Get current device location properties being used.
      var dlProps = DeviceLocationService.Instance.GetProperties();
      var accuracy = dlProps.AccuracyThreshold;
    Inheritance Hierarchy
    System.Object
       ArcGIS.Desktop.Framework.Contracts.PropertyChangedBase
          ArcGIS.Desktop.Core.DeviceLocation.DeviceLocationSource
             ArcGIS.Desktop.Core.DeviceLocation.SerialPortDeviceLocationSource
    Requirements
