ArcGIS.Desktop.Mapping Namespace / RasterLayer Class / InterpolateShapeVertices Method
The multipart to be interpolated. It must be a polyline or polygon.
    InterpolateShapeVertices Method (RasterLayer)
    Interpolates Z values for a geometric shape from the raster surface layer at it's vertices only. Bilinear interpolation is used. This method requires a 3D Analyst license. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function InterpolateShapeVertices( _
       ByVal multipart As Multipart _
    ) As Geometry
    public Geometry InterpolateShapeVertices(
       Multipart multipart
    Parameters
    multipart
    Return Value
    A ArcGIS.Core.Geometry.Geometry with surface elevation z values.
    Exceptions
    ExceptionDescription
    multipart cannot be null.
    multipart cannot be empty.
    An exception occurred within the InterpolateShapeVertices calculation.
    A 3D Analyst license is required.
    Remarks
    A null geometry is returned if any portion of the input falls outside the surface.
    InterpolateShapeVertices will handle differences in spatial reference between the input shape and the surface. It will project (a copy of) the input geometry to match the surface for the sake of interpolation. It will then re-project the output geometry so it's the same as the input shape.
    Requirements
    ArcGIS Pro version: 3.4 or higher.
