Function GetPredefinedProjectUnitFormats( _ ByVal unitFormat As UnitFormatType _ ) As IList(Of DisplayUnitFormat)
IList<DisplayUnitFormat> GetPredefinedProjectUnitFormats( UnitFormatType unitFormat )
Parameters
- unitFormat
//Note: Must be on the QueuedTask.Run()
var unit_formats = Enum.GetValues(typeof(UnitFormatType))
.OfType<UnitFormatType>().ToList();
System.Diagnostics.Debug.WriteLine("All available units\r\n");
foreach (var unit_format in unit_formats)
var units = DisplayUnitFormats.Instance.GetPredefinedProjectUnitFormats(unit_format);
System.Diagnostics.Debug.WriteLine(unit_format.ToString());
foreach (var display_unit_format in units)
var line = $"{display_unit_format.DisplayName}, {display_unit_format.UnitCode}";
System.Diagnostics.Debug.WriteLine(line);
System.Diagnostics.Debug.WriteLine("");
// Note: Must be on the QueuedTask.Run()
//UnitFormatType.Angular, UnitFormatType.Area, UnitFormatType.Distance,
//UnitFormatType.Direction, UnitFormatType.Location
//Get the full list of all available location units
var all_units = DisplayUnitFormats.Instance.GetPredefinedProjectUnitFormats(
UnitFormatType.Location);
//keep units with an even factory code
var list_units = all_units.Where(du => du.UnitCode % 2 == 0).ToList();
//set them as the new location unit collection. A new default is not being specified...
DisplayUnitFormats.Instance.SetProjectUnitFormats(list_units);
//set them as the new location unit collection along with a new default
list_units, list_units.First());
//Note: UnitFormatType.Page, UnitFormatType.Symbol2D, UnitFormatType.Symbol3D
//cannot be set.
