ArcGIS.Desktop.Core.UnitFormats Namespace / IDisplayUnitFormats Interface / GetProjectUnitFormats Method
Example
    GetProjectUnitFormats Method (IDisplayUnitFormats)
    Get the current list of unit formats in the current project for the given UnitFormatType
    Syntax
    Parameters
    unitFormat
    Return Value
    Example
    Get The List of Unit Formats for the Current Project
      // Note: Must be on the QueuedTask.Run()
      var unit_formats = Enum.GetValues(typeof(UnitFormatType))
                      .OfType<UnitFormatType>().ToList();
      System.Diagnostics.Debug.WriteLine("Project units\r\n");
      foreach (var unit_format in unit_formats)
        var units = DisplayUnitFormats.Instance.GetProjectUnitFormats(unit_format);
        System.Diagnostics.Debug.WriteLine(unit_format.ToString());
        foreach (var display_unit_format in units)
          var line = $"{display_unit_format.DisplayName}, {display_unit_format.UnitCode}";
          System.Diagnostics.Debug.WriteLine(line);
        System.Diagnostics.Debug.WriteLine("");
    Get A Specific List of Unit Formats for the Current Project
      //Must be on the QueuedTask.Run()
      //UnitFormatType.Angular, UnitFormatType.Area, UnitFormatType.Distance,
      //UnitFormatType.Direction, UnitFormatType.Location, UnitFormatType.Page
      //UnitFormatType.Symbol2D, UnitFormatType.Symbol3D
      var units = DisplayUnitFormats.Instance.GetProjectUnitFormats(UnitFormatType.Distance);
      // Use units;
    Update Unit Formats for the Project
      var angle_units = DisplayUnitFormats.Instance.GetProjectUnitFormats(UnitFormatType.Angular);
      //Edit the display name of each unit - append the abbreviation
      foreach (var unit in angle_units)
        unit.DisplayName = $"{unit.DisplayName} ({unit.Abbreviation})";
      //apply the changes to the units and set the default to be the first entry
      DisplayUnitFormats.Instance.SetProjectUnitFormats(angle_units, angle_units.First());
      //The project must be saved to persist the changes...
    Requirements
