Sub SetDefaultProjectUnitFormat( _ ByVal defaultFormat As DisplayUnitFormat _ )
void SetDefaultProjectUnitFormat( DisplayUnitFormat defaultFormat )
Parameters
- defaultFormat
// Note: Must be on the QueuedTask.Run()
var unit_formats = Enum.GetValues(typeof(UnitFormatType)).OfType<UnitFormatType>().ToList();
foreach (var unit_type in unit_formats)
var current_default = DisplayUnitFormats.Instance.GetDefaultProjectUnitFormat(unit_type);
//Arbitrarily pick the last unit in each unit format list
var replacement = DisplayUnitFormats.Instance.GetProjectUnitFormats(unit_type).Last();
DisplayUnitFormats.Instance.SetDefaultProjectUnitFormat(replacement);
var line = $"{current_default.DisplayName}, {current_default.UnitName}, {current_default.UnitCode}";
var line2 = $"{replacement.DisplayName}, {replacement.UnitName}, {replacement.UnitCode}";
System.Diagnostics.Debug.WriteLine($"Format: {unit_type}");
System.Diagnostics.Debug.WriteLine($" Current default: {line}");
System.Diagnostics.Debug.WriteLine($" Replacement default: {line2}");
