ArcGIS.Desktop.Core.UnitFormats Namespace / DisplayUnitFormat Class / DisplayName Property
Example
    DisplayName Property (DisplayUnitFormat)
    Gets and sets the display name of the unit format
    Syntax
    Public Property DisplayName As String
    public string DisplayName {get; set;}
    Remarks
    This name is typically localized
    Example
    Get the Current Map Location Unit
        //var map = MapView.Active.Map;
        //Note: Must be on the QueuedTask.Run()
        //Get the current location unit
        var loc_unit = map.GetLocationUnitFormat();
        var line = $"{loc_unit.DisplayName}, {loc_unit.UnitCode}";
        System.Diagnostics.Debug.WriteLine(line);
    Requirements
