ArcGIS.Desktop.Core.UnitFormats Namespace / DisplayUnitFormats Class / GetPredefinedProjectUnitFormats Method
The predefined unit format list to return
    GetPredefinedProjectUnitFormats Method (DisplayUnitFormats)
    Gets the complete list of available unit formats in the current project for the given UnitFormatType. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetPredefinedProjectUnitFormats( _
       ByVal unitFormat As UnitFormatType _
    ) As IList(Of DisplayUnitFormat)
    public IList<DisplayUnitFormat> GetPredefinedProjectUnitFormats(
       UnitFormatType unitFormat
    Parameters
    unitFormat
    Return Value
    Exceptions
    ExceptionDescription
    This method or property must be called within the lambda passed to QueuedTask.Run
    Remarks
    The predefined list does not vary between projects.
    If there is no project open the list of predefined units defined for the application is returned.
    Requirements
