ArcGIS.Desktop.Mapping Namespace / ParcelFabricExtensions Class / GetActiveRecord Method
The parcel layer.
Example
    Gets the active record information.
    Syntax
    Public Shared Function GetActiveRecord( _
       ByVal parcelLayer As ParcelLayer _
    ) As ParcelRecord
    public static ParcelRecord GetActiveRecord(
       ParcelLayer parcelLayer
    Parameters
    parcelLayer
    The parcel layer.
    Return Value
    Exceptions
    ExceptionDescription
    Insufficient license. This method requires a standard license.
    Example
    Get the active record
      string errorMessage = await QueuedTask.Run(() =>
        try
          var myParcelFabricLayer = MapView.Active.Map.GetLayersAsFlattenedList().OfType<ParcelLayer>().FirstOrDefault();
          //if there is no fabric in the map then bail
          if (myParcelFabricLayer == null)
            return "There is no fabric in the map.";
          var theActiveRecord = myParcelFabricLayer.GetActiveRecord();
          if (theActiveRecord == null)
            return "There is no Active Record. Please set the active record and try again.";
        catch (Exception ex)
          return ex.Message;
        return "";
      if (!string.IsNullOrEmpty(errorMessage))
        MessageBox.Show(errorMessage, "Get Active Record.");
    Assign features to active record
       //check for selected layer
       if (MapView.Active.GetSelectedLayers().Count == 0)
         return "Please select a source feature layer in the table of contents.";
       //first get the feature layer that's selected in the table of contents
       var srcFeatLyr = MapView.Active.GetSelectedLayers().OfType<FeatureLayer>().FirstOrDefault();
         return "No parcel layer found in the map.";
       try
         var editOper = new EditOperation()
           Name = "Assign Features to Record",
           ProgressMessage = "Assign Features to Record...",
           ShowModalMessageAfterFailure = true,
           SelectNewFeatures = true,
           SelectModifiedFeatures = false
         //add parcel type layers and their feature ids to a new Dictionary
         var ids = new List<long>(srcFeatLyr.GetSelection().GetObjectIDs());
         var sourceFeatures = new Dictionary<MapMember, List<long>>
           { srcFeatLyr, ids }
         editOper.AssignFeaturesToRecord(myParcelFabricLayer,
           SelectionSet.FromDictionary(sourceFeatures), theActiveRecord);
         if (!editOper.Execute())
           return editOper.ErrorMessage;
         return ex.Message;
       return "";
        MessageBox.Show(errorMessage, "Assign Features To Record.");
    Create parcel seeds
    try
      var guid = theActiveRecord.Guid;
        Name = "Create Parcel Seeds",
        ProgressMessage = "Create Parcel Seeds...",
      editOper.CreateParcelSeedsByRecord(myParcelFabricLayer, guid, MapView.Active.Extent);
      return ex.Message;
    return "";
    Build parcels
    try
        return "Parcel layer not found in map.";
        Name = "Build Parcels",
        ProgressMessage = "Build Parcels...",
        SelectModifiedFeatures = true
      editOper.BuildParcelsByRecord(myParcelFabricLayer, guid);
      return ex.Message;
    return "";
    Requirements
