ArcGIS.Desktop.Mapping Namespace / ParcelFabricExtensions Class / GetPointsLayerAsync Method
The parcel layer.
Example
    Gets the points layer for the given parcel layer.
    Syntax
    Public Shared Function GetPointsLayerAsync( _
       ByVal parcelLayer As ParcelLayer _
    ) As Task(Of List(Of FeatureLayer))
    public static Task<List<FeatureLayer>> GetPointsLayerAsync(
       ParcelLayer parcelLayer
    Parameters
    parcelLayer
    The parcel layer.
    Return Value
    A Task to the set of point layers.
    Exceptions
    ExceptionDescription
    Insufficient license. This method requires a standard license.
    Example
    Get parcel features
      string sReportResult = "Polygon Information --" + Environment.NewLine;
      string sParcelTypeName = "tax";
      string errorMessage = await QueuedTask.Run(async () =>
        var myParcelFabricLayer =
          MapView.Active.Map.GetLayersAsFlattenedList().OfType<ParcelLayer>().FirstOrDefault();
        //if there is no fabric in the map then bail
        if (myParcelFabricLayer == null)
          return "There is no fabric layer in the map.";
        //first get the parcel type feature layer
        var featSrcLyr = myParcelFabricLayer.GetParcelPolygonLayerByTypeNameAsync(sParcelTypeName).Result.FirstOrDefault();
        if (featSrcLyr.SelectionCount == 0)
          return "There is no selection on the " + sParcelTypeName + " layer.";
        sReportResult += " Parcel Type: " + sParcelTypeName + Environment.NewLine;
        sReportResult += " Poygons: " + featSrcLyr.SelectionCount + Environment.NewLine + Environment.NewLine;
        try
          // ------- get the selected parcels ---------
          var ids = new List<long>((featSrcLyr as FeatureLayer).GetSelection().GetObjectIDs());
          var sourceParcels = new Dictionary<MapMember, List<long>>
            { featSrcLyr, ids }
          ParcelFeatures parcFeatures =
                          await myParcelFabricLayer.GetParcelFeaturesAsync(SelectionSet.FromDictionary(sourceParcels));
          //since we know that we want to report on Tax lines only, and for this functionality
          // we can use any of the Tax line layer instances (if there happens to be more than one)
          // we can get the first instance as follows
          FeatureLayer myLineFeatureLyr =
              myParcelFabricLayer.GetParcelLineLayerByTypeNameAsync(sParcelTypeName).Result.FirstOrDefault();
          if (myLineFeatureLyr == null)
            return sParcelTypeName + " line layer not found";
          FeatureLayer myPointFeatureLyr =
              myParcelFabricLayer.GetPointsLayerAsync().Result.FirstOrDefault();
          if (myPointFeatureLyr == null)
            return "fabric point layer not found";
          var LineInfo = parcFeatures.Lines; //then get the line information from the parcel features object
                                             //... and then do some work for each of the lines
          int iRadiusAttributeCnt = 0;
          int iDistanceAttributeCnt = 0;
          sReportResult += "Line Information --";
          foreach (KeyValuePair<string, List<long>> kvp in LineInfo)
            if (!kvp.Key.Equals(sParcelTypeName, StringComparison.CurrentCultureIgnoreCase))
              continue; // ignore any other lines from different parcel types
            foreach (long oid in kvp.Value)
              var insp = myLineFeatureLyr.Inspect(oid);
              var dRadius = insp["RADIUS"];
              var dDistance = insp["DISTANCE"];
              if (dRadius != DBNull.Value)
                iRadiusAttributeCnt++;
              if (dDistance != DBNull.Value)
                iDistanceAttributeCnt++;
              //Polyline poly = (Polyline)insp["SHAPE"];
            sReportResult += Environment.NewLine + " Distance attributes: " + iDistanceAttributeCnt.ToString();
            sReportResult += Environment.NewLine + " Radius attributes: " + iRadiusAttributeCnt.ToString();
          var PointInfo = parcFeatures.Points; //get the point information from the parcel features object
                                               //... and then do some work for each of the points
          sReportResult += Environment.NewLine + Environment.NewLine + "Point Information --";
          int iFixedPointCnt = 0;
          int iNonFixedPointCnt = 0;
          foreach (long oid in PointInfo)
            var insp = myPointFeatureLyr.Inspect(oid);
            var isFixed = insp["ISFIXED"];
            if (isFixed == DBNull.Value || (int)isFixed == 0)
              iNonFixedPointCnt++;
            else
              iFixedPointCnt++;
            // var pt = insp["SHAPE"];
          sReportResult += Environment.NewLine + " Fixed Points: " + iFixedPointCnt.ToString();
          sReportResult += Environment.NewLine + " Non-Fixed Points: " + iNonFixedPointCnt.ToString();
        catch (Exception ex)
          return ex.Message;
        return "";
      if (!string.IsNullOrEmpty(errorMessage))
        MessageBox.Show(errorMessage, "Get Parcel Features");
      else
        MessageBox.Show(sReportResult, "Get Parcel Features");
    Requirements
