ArcGIS.Core.CIM Namespace / CIMMaplexLabelPlacementProperties Class / MaximumCharacterSpacing Property
Example
    Gets or sets the maximum character spacing. Character spacing may be increased up to this limit.
    Syntax
    public double MaximumCharacterSpacing {get; set;}
    Public Property MaximumCharacterSpacing As Double
    Example
    Spread labels across Polygon geometry
      var map = MapView.Active?.Map;
      if (map == null)
        return;
      await QueuedTask.Run(() =>
        //Check if the label engine is Maplex or standard.
        CIMGeneralPlacementProperties labelEngine = map.GetDefinition().GeneralPlacementProperties;
        if (labelEngine is CIMStandardGeneralPlacementProperties)
          return;
        //Get the layer's definition
        var lyrDefn = featureLayer.GetDefinition() as CIMFeatureLayer;
        //Get the label classes - we need the first one
        var listLabelClasses = lyrDefn.LabelClasses.ToList();
        var theLabelClass = listLabelClasses.FirstOrDefault();
        //Spread Labels (words and characters to fill feature)
        // Spread words to fill feature
        theLabelClass.MaplexLabelPlacementProperties.SpreadWords = true;
        //Spread Characters to a fixed limit of 50%
        theLabelClass.MaplexLabelPlacementProperties.SpreadCharacters = true;
        theLabelClass.MaplexLabelPlacementProperties.MaximumCharacterSpacing = 50.0;
        lyrDefn.LabelClasses = listLabelClasses.ToArray(); //Set the labelClasses back
        featureLayer.SetDefinition(lyrDefn); //set the layer's definition
    Requirements
