ArcGIS.Desktop.Mapping Namespace / ParcelFabricExtensions Class / SetActiveRecordAsync Method / SetActiveRecordAsync(ParcelLayer,String) Method
The parcel layer.
The name of the parcel record feature to be set as the current record.
Example
    Sets the active record.
    Syntax
    Public Overloads Shared Function SetActiveRecordAsync( _
       ByVal parcelLayer As ParcelLayer, _
       ByVal name As String _
    ) As Task(Of Boolean)
    public static Task<bool> SetActiveRecordAsync(
       ParcelLayer parcelLayer,
       string name
    Parameters
    parcelLayer
    The parcel layer.
    name
    Return Value
    A Task to a bool indicating if the active record is set.
    Exceptions
    ExceptionDescription
    Insufficient license. This method requires a standard license.
    Remarks
    All clients, including the parcel heads-up-display on the active map, will be notified and use the values given. Values for the parcel record must be set correctly to match the underlying data.
    Example
    Set the active record
      string errorMessage = await QueuedTask.Run(async () =>
        try
          string sExistingRecord = "MyRecordName";
          var myParcelFabricLayer = MapView.Active.Map.GetLayersAsFlattenedList().OfType<ParcelLayer>().FirstOrDefault();
          //if there is no fabric in the map then bail
          if (myParcelFabricLayer == null)
            return "There is no fabric in the map.";
          bool bSuccess = await myParcelFabricLayer.SetActiveRecordAsync(sExistingRecord);
          if (!bSuccess)
            return "No record called " + sExistingRecord + " was found.";
        catch (Exception ex)
          return ex.Message;
        return "";
      if (!string.IsNullOrEmpty(errorMessage))
        MessageBox.Show(errorMessage, "Set Active Record.");
    Requirements
