ArcGIS.Desktop.Framework.Utilities Namespace / EventLog Class / Write Method / Write(EventType,String,Boolean) Method
The type of event to log.
User defined entry describing the event.
If true, event is written to disk immediately.
    Creates a timestamped event record of the specified type. Event is flushed immediately to disk if flush is set to true. The type of event to log.User defined entry describing the event.If true, event is written to disk immediately.
    Syntax
    public static void Write(
       EventLog.EventType type,
       string entry,
       bool flush
    Public Overloads Shared Sub Write( _
       ByVal type As EventLog.EventType, _
       ByVal entry As String, _
       Optional ByVal flush As Boolean _
    Parameters
    type
    entry
    flush
    Requirements
