ArcGIS.Desktop.Layouts Namespace / Layout Class / DeleteElements Method / DeleteElements(IEnumerable<Element>) Method
The elements being removed
Example
    Deletes the elements from a page layout. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Overloads Sub DeleteElements( _
       Optional ByVal elements As IEnumerable(Of Element) _
    public void DeleteElements(
       IEnumerable<Element> elements
    Parameters
    elements
    Exceptions
    ExceptionDescription
    elements must belong to layout 'URI'
    Remarks
    If elements is null then all elements are deleted.
    If a group element is provided in the list of elements to be deleted then the group element and all its children will be deleted.
    If a child of a group element is provided in the list in addition to its parent then the parent takes precedence (i.e. the entire group element is deleted and not just that child)
    Example
    Delete Layout Elements
      //Note: Must be on QueuedTask.Run
      var elementsToRemove = layout.GetSelectedElements();
      layout.DeleteElements(elementsToRemove);
    Delete an element or elements on a layout
      //Delete an element or elements on a layout.
      //Delete a specific element on a layout
      //Find a single specific element
      Element rect = layout.FindElement("Rectangle") as Element;
      layout.DeleteElement(rect);
      //Or delete a group of elements using a filter
      layout.DeleteElements(item => item.Name.Contains("Clone"));
      //Or delete all elements on a layout
      layout.DeleteElements(item => true);
    Requirements
