Return Value
True if the metadata is editable
| Exception | Description |
| ArcGIS.Core.CalledOnWrongThreadException | This method or property must be called within the lambda passed to QueuedTask.Run. |
//Note: Must be on QueuedTask.Run
//Gets the Layout metadata.
var layout_xml = layout.GetMetadata();
//Can metadata be edited?
if (layout.GetCanEditMetadata())
//Set the metadata back
layout.SetMetadata(layout_xml);
