ArcGIS.Desktop.Layouts Namespace / Layout Class / GetMetadata Method
Example
    GetMetadata Method (Layout)
    Gets the Layout metadata. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetMetadata() As String
    public string GetMetadata()
    Return Value
    The xml formatted metadata
    Exceptions
    ExceptionDescription
    Example
    Layout Metadata
      //Note: Must be on QueuedTask.Run
      //Gets the Layout metadata.
      var layout_xml = layout.GetMetadata();
      //Can metadata be edited?
      if (layout.GetCanEditMetadata())
        //Set the metadata back
        layout.SetMetadata(layout_xml);
    Requirements
