ArcGIS.Desktop.Layouts Namespace / Layout Class / SendBackward Method / SendBackward(Element) Method
The element to send backward
Example
    Send the element backward within its parent's element collection. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Overloads Sub SendBackward( _
       ByVal element As Element _
    public void SendBackward(
       Element element
    Parameters
    element
    Exceptions
    ExceptionDescription
    Value cannot be null: element
    elements must belong to layout 'URI'
    Remarks
    Refer to CanSendBackward(Element) to check whether an element can be sent backward. Element z order can only be changed relative to its parent's element collection. The bottom element will have a z order of 0 within the element parent's element collection. Check z order with Element.ZOrder.
    Example
    Ordering: Send backward and Bring forward
      //Note: Must be on QueuedTask.Run
      //get the current selection set
      var sel_elems = layout.GetSelectedElements();
      //can they be brought forward? This will also check that all elements have the same parent
      if (layout.CanBringForward(sel_elems))
        //bring forward
        layout.BringForward(sel_elems);
        //bring to front (of parent)
        //graphicsLayer.BringToFront(sel_elems);
      else if (layout.CanSendBackward(sel_elems))
        //send back
        layout.SendBackward(sel_elems);
        //send to the back (of parent)
        //graphicsLayer.SendToBack(sel_elems);
    Requirements
