ArcGIS.Desktop.Layouts Namespace / Layout Class / SendBackward Method / SendBackward(IEnumerable<Element>) Method
The elements to send backward
Example
    Send the elements backward within their parent's element collection. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Overloads Sub SendBackward( _
       ByVal elements As IEnumerable(Of Element) _
    public void SendBackward(
       IEnumerable<Element> elements
    Parameters
    elements
    Exceptions
    ExceptionDescription
    elements cannot be null or empty
    elements must belong to layout 'URI'
    element parents must be the same and non-null
    Remarks
    Refer to CanSendBackward(IEnumerable<Element>) to check whether the elements can be sent backward. Element z order can only be changed relative to their parent's element collection. All elements must have the same parent. The bottom element will have a z order of 0 within the element parent's element collection. Check individual element z order with Element.ZOrder.
    Example
    Ordering: Send backward and Bring forward
      //Note: Must be on QueuedTask.Run
      //get the current selection set
      var sel_elems = layout.GetSelectedElements();
      //can they be brought forward? This will also check that all elements have the same parent
      if (layout.CanBringForward(sel_elems))
        //bring forward
        layout.BringForward(sel_elems);
        //bring to front (of parent)
        //graphicsLayer.BringToFront(sel_elems);
      else if (layout.CanSendBackward(sel_elems))
        //send back
        layout.SendBackward(sel_elems);
        //send to the back (of parent)
        //graphicsLayer.SendToBack(sel_elems);
    Requirements
