ArcGIS.Desktop.Layouts Namespace / Layout Class / SendToBack Method / SendToBack(IEnumerable<Element>) Method
The elements to send to the back
    Send the elements to the back of their parent's element collection. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Overloads Sub SendToBack( _
       ByVal elements As IEnumerable(Of Element) _
    public void SendToBack(
       IEnumerable<Element> elements
    Parameters
    elements
    Exceptions
    ExceptionDescription
    elements cannot be null or empty
    elements must belong to layout 'URI'
    element parents must be the same and non-null
    Remarks
    Refer to CanSendBackward(IEnumerable<Element>) to check whether the elements can be sent back. Element z order can only be changed relative to their parent's element collection. All elements must have the same parent. The bottom element will have a z order of 0 within the element parent's element collection. Check individual element z order with Element.ZOrder.
    Requirements
