ArcGIS.Desktop.Layouts Namespace / MapFrame Class / MapToPage Method / MapToPage(MapPoint) Method
The point in map coordinates
Example
    Translates a point in map coordinates to a point in page coordinates. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Overloads Function MapToPage( _
       ByVal mapPoint As MapPoint _
    ) As MapPoint
    public MapPoint MapToPage(
       MapPoint mapPoint
    Parameters
    mapPoint
    Return Value
    A point in page coordinates
    Exceptions
    ExceptionDescription
    Mapframe must contain a 2D map
    mapPoint
    Remarks
    The map coordinates must be in the spatial reference of the map associated with the map frame. Page coordinates can only be translated for 2D maps. If the map frame does not contain a 2D map, an System.InvalidOperationException is thrown. If either map coordinate value is double.NaN then a point with X, Y both set to System.Double.NaN is returned.
    Example
      //Note: Must be on QueuedTask.Run
      var pointSymbol = SymbolFactory.Instance.ConstructPointSymbol(ColorFactory.Instance.BlackRGB, 8);
      //Convert the clicked point in client coordinates to the corresponding map coordinates.
      //clicked point can be from a Map Tool's HandleMouseDownAsync callback.
      //MapViewMouseButtonEventArgs ClientPoint property.
      Point clickedPoint;
      var clickedMapPoint = MapView.Active.ClientToMap(clickedPoint);
      ArcGIS.Desktop.Framework.Dialogs.MessageBox.Show(string.Format("X: {0} Y: {1} Z: {2}",
          mapPoint.X, mapPoint.Y, mapPoint.Z), "Map Coordinates");
      //Get the corresponding layout point
      var pointOnLayoutFrame = mapFrame.MapToPage(mapPoint);
      //Create a point graphic on the Layout.
      var cimGraphicElement = new CIMPointGraphic
        Location = pointOnLayoutFrame,
        Symbol = pointSymbol.MakeSymbolReference()
      //Or use GraphicFactory
      var cimGraphicElement2 = GraphicFactory.Instance.CreateSimpleGraphic(
              pointOnLayoutFrame, pointSymbol);
      ElementFactory.Instance.CreateGraphicElement(layout, cimGraphicElement);
      ElementFactory.Instance.CreateGraphicElement(layout, cimGraphicElement2);
    Requirements
