ArcGIS.Desktop.Layouts Namespace / MapFrame Class / PageToMap Method / PageToMap(MapPoint) Method
The point in page coordinates
Example
    Translates a point in page coordinates to a point in map coordinates. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public MapPoint PageToMap(
       MapPoint pagePoint
    Public Overloads Function PageToMap( _
       ByVal pagePoint As MapPoint _
    ) As MapPoint
    Parameters
    pagePoint
    Return Value
    A point in map coordinates
    Exceptions
    ExceptionDescription
    Mapframe must contain a 2D map
    pagePoint
    Remarks
    The map coordinates will be in the spatial reference of the map associated with the map frame. Page coordinates can only be translated for 2D maps. If the map frame does not contain a 2D map, an System.InvalidOperationException is thrown. If either page coordinate value is double.NaN then a point with X, Y both set to System.Double.NaN is returned.
    Example
      var pointSymbol = SymbolFactory.Instance.ConstructPointSymbol(ColorFactory.Instance.BlackRGB, 8);
      var activeMapView = MapView.Active;
      await QueuedTask.Run(() =>
        var graphicsLayer = activeMapView.Map.GetLayersAsFlattenedList().OfType<GraphicsLayer>().FirstOrDefault();
        //Get a point in the center of the Map frame
        var mapFrameCenterPoint = mapFrame.GetBounds().CenterCoordinate;
        //Convert to MapPoint
        var pointInMapFrame = MapPointBuilderEx.CreateMapPoint(mapFrameCenterPoint);
        //Find the corresponding point in the MapView
        var pointOnMap = mapFrame.PageToMap(pointInMapFrame);
        //Create a point graphic on the MapView.
        var cimGraphicElement = new CIMPointGraphic
          Location = pointOnMap,
          Symbol = pointSymbol.MakeSymbolReference()
        graphicsLayer.AddElement(cimGraphicElement);
    Requirements
