ArcGIS.Desktop.Reports Namespace / IReportElementFactory Interface / CreateRectangleParagraphGraphicElement Method
    CreateRectangleParagraphGraphicElement Method (IReportElementFactory)
    Overload List
    OverloadDescription
    Creates a graphic rectangle text element on a layout from an envelope geometry with an added parameter to set the text symbol. This method must be called on the MCT. Use QueuedTask.Run.
    Creates a dynamic picture element defined by a field on a report from an envelope geometry. This method must be called on the MCT. Use QueuedTask.Run.
    Requirements
