ArcGIS.Desktop.Reports Namespace / ReportElementFactory Class / CreateFieldStatisticTextElement Method
IElementContainer
Envelope
ReportFieldStatistic
CIMTextSymbol
    CreateFieldStatisticTextElement Method (ReportElementFactory)
    Creates a field statistic text element on a report from an envelope geometry. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Parameters
    elementContainer
    IElementContainer
    envelope
    Envelope
    reportFieldStatistic
    textSymbol
    CIMTextSymbol
    Return Value
    Returns a GraphicElement
    Exceptions
    ExceptionDescription
    Invalid report section.
    Invalid report.
    Element extents outside section.
    Cannot add element to this section type.
    Failed to create text element.
    Remarks
    The element gets added to the group at the topmost position.
    Requirements
