ArcGIS.Desktop.Mapping Namespace / Layer Class / GetCanEditMetadata Method
    GetCanEditMetadata Method (Layer)
    Gets whether the Layer metadata can be edited or not. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Overrides Function GetCanEditMetadata() As Boolean
    public override bool GetCanEditMetadata()
    Return Value
    True if the metadata is editable
    Exceptions
    ExceptionDescription
    Remarks
    Layer metadata is typically editable unless the Layer is using an underlying data source for metadata or the .aprx is not editable. Sub layer types do not support metadata. They typically have a single source, specified on the parent layer, that controls the metadata.
    Requirements
