ArcGIS.Desktop.Mapping Namespace / Layer Class / GetMetadata Method
    GetMetadata Method (Layer)
    Gets the Layer metadata. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Overrides Function GetMetadata() As String
    public override string GetMetadata()
    Return Value
    The xml formatted metadata
    Exceptions
    ExceptionDescription
    Remarks
    Sub layer types do not support metadata. They typically have a single source, specified on the parent layer, that controls the metadata.
    Requirements
