Return Value
True if the metadata is editable
| Exception | Description |
| ArcGIS.Core.CalledOnWrongThreadException | This method or property must be called within the lambda passed to QueuedTask.Run. |
await QueuedTask.Run(() =>
//Get map's metadata
var mapMetadata = map.GetMetadata();
//TODO:Make edits to metadata using the retrieved mapMetadata string.
//Set the modified metadata back to the map.
if (map.GetCanEditMetadata())
map.SetMetadata(mapMetadata);
