ArcGIS.Desktop.Mapping Namespace / Map Class / GetMetadata Method
Example
    GetMetadata Method (Map)
    Gets the Map metadata. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public string GetMetadata()
    Public Function GetMetadata() As String
    Return Value
    The xml formatted metadata
    Exceptions
    ExceptionDescription
    Example
    Get and Set Map Metadata
      await QueuedTask.Run(() =>
        //Get map's metadata
        var mapMetadata = map.GetMetadata();
        //TODO:Make edits to metadata using the retrieved mapMetadata string.
        //Set the modified metadata back to the map.
        if (map.GetCanEditMetadata())
          map.SetMetadata(mapMetadata);
    Requirements
