var map = MapView.Active?.Map;
if (map == null)
return;
await QueuedTask.Run(() =>
//Check if the label engine is Maplex or standard.
CIMGeneralPlacementProperties labelEngine = map.GetDefinition().GeneralPlacementProperties;
if (labelEngine is CIMStandardGeneralPlacementProperties)
return;
//Get the layer's definition
var lyrDefn = featureLayer.GetDefinition() as CIMFeatureLayer;
//Get the label classes - we need the first one
var listLabelClasses = lyrDefn.LabelClasses.ToList();
var theLabelClass = listLabelClasses.FirstOrDefault();
//Spread Labels (words and characters to fill feature)
// Spread words to fill feature
theLabelClass.MaplexLabelPlacementProperties.SpreadWords = true;
//Spread Characters to a fixed limit of 50%
theLabelClass.MaplexLabelPlacementProperties.SpreadCharacters = true;
theLabelClass.MaplexLabelPlacementProperties.MaximumCharacterSpacing = 50.0;
lyrDefn.LabelClasses = listLabelClasses.ToArray(); //Set the labelClasses back
featureLayer.SetDefinition(lyrDefn); //set the layer's definition
