ArcGIS.Desktop.Mapping Namespace / VoxelLayer Class / DeleteSection Method
The definition of the locked section to delete
Example
    DeleteSection Method (VoxelLayer)
    Delete the specified locked section. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public void DeleteSection(
       LockedSectionDefinition lockedSectionDef
    Public Sub DeleteSection( _
       ByVal lockedSectionDef As LockedSectionDefinition _
    Parameters
    lockedSectionDef
    Exceptions
    ExceptionDescription
    This method or property must be called within the lambda passed to QueuedTask.Run
    Locked section not found in the collection of sections
    Locked section is null
    Example
    Delete a Locked Section
      await QueuedTask.Run(() =>
        if (voxelLayer.GetLockedSections().Count() == 0)
          return;
        //Delete the last locked section from the collection of
        //locked sections
        voxelLayer.DeleteSection(voxelLayer.GetLockedSections().Last());
    Requirements
