ArcGIS.Desktop.Mapping Namespace / VoxelLayer Class / GetNormal Method
Orientation angle in degrees.
Tilt angle in degrees.
Example
    GetNormal Method (VoxelLayer)
    Gets the normal unit vector for the provided orientation and tilt. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public Coordinate3D GetNormal(
       double orientation,
       double tilt
    Public Function GetNormal( _
       ByVal orientation As Double, _
       ByVal tilt As Double _
    ) As Coordinate3D
    Parameters
    orientation
    tilt
    Return Value
    A ArcGIS.Core.Geometry.Coordinate3D representing the normal unit vector
    Exceptions
    ExceptionDescription
    This method or property must be called within the lambda passed to QueuedTask.Run
    Example
    Create a Slice
      await QueuedTask.Run(() =>
        if (voxelLayer.Visualization != VoxelVisualization.Volume)
          voxelLayer.SetVisualization(VoxelVisualization.Volume);
        voxelLayer.SetSliceContainerExpanded(true);
        voxelLayer.SetSliceContainerVisibility(true);
        //To stop the Voxel Exploration Dockpane activating use:
        voxelLayer.AutoShowExploreDockPane = false;
        //This is useful if u have your own dockpane currently activated...
        //Use the SelectedVariableProfile to get the slices currently in the TOC
        //via its associated volume
        var volume = voxelLayer.SelectedVariableProfile.Volume;
        var volumeSize = volume.GetVolumeSize();
        //Orientation 90 degrees (West), Tilt 0.0 (vertical)
        //Convert to a normal
        var normal = voxelLayer.GetNormal(90, 0.0);
        //Create the slice at the voxel mid-point. VoxelPosition
        //is specified in voxel-space coordinates
        //Create the slice on the respective volume
        volume.CreateSlice(new SliceDefinition()
          Name = "Middle Slice",
          VoxelPosition = new Coordinate3D(volumeSize.X / 2, volumeSize.Y / 2, volumeSize.Z / 2),
          Normal = normal,
          IsVisible = true
        //reset if needed...
        voxelLayer.AutoShowExploreDockPane = true;
    Change Tilt on a Slice
        //Normally, it would be set in your dockpane
        var slice = volume.GetSlices().First(s => s.Name == "Change Tilt Slice");
        (double orientation, double tilt) = voxelLayer.GetOrientationAndTilt(slice.Normal);
        //Convert orientation and tilt to a normal
        slice.Normal = voxelLayer.GetNormal(orientation, 45.0);
        volume.UpdateSlice(slice);
        //reset if needed...Normally this might be when your dockpane
        //was de-activated (ie "closed")
    Create a Section at the Voxel MidPoint
        if (voxelLayer.Visualization != VoxelVisualization.Surface)
          voxelLayer.SetVisualization(VoxelVisualization.Surface);
        voxelLayer.SetSectionContainerExpanded(true);
        voxelLayer.SetSectionContainerVisibility(true);
        //Create a section that cuts the volume in two on the vertical plane
        //Use the SelectedVariableProfile to get the sections
        //Orientation 90 degrees (due West), Tilt 0 degrees
        //Position must be specified in voxel space
        volume.CreateSection(new SectionDefinition()
          Name = "Middle Section",
          Normal = normal,
          IsVisible = true
    Create Sections in a Circle Pattern
        //180 degrees orientation is due South. 90 degrees orientation is due west.
        var south = 180.0;
        var num_sections = 12;
        var spacing = 1 / (double)num_sections;
        //Create a section every nth degree of orientation. Each section
        //bisects the middle of the voxel
        for (int s = 0; s < num_sections; s++)
          var orientation = south * (s * spacing);
            Name = $"Circle {s + 1}",
            Normal = voxelLayer.GetNormal(orientation, 0.0),
            IsVisible = true
    Create Sections Diagonally across the Voxel
        //make a diagonal across the voxel
        var voxel_pos = new Coordinate3D(0, 0, volumeSize.Z);
        var voxel_pos_ur = new Coordinate3D(volumeSize.X, volumeSize.Y, volumeSize.Z);
        var lineBuilder = new LineBuilderEx(voxel_pos, voxel_pos_ur, null);
        var diagonal = PolylineBuilderEx.CreatePolyline(lineBuilder.ToSegment());
        //change as needed
        var orientation = 20.0; //(approx NNW)
        var tilt = -15.0;
        var normal = voxelLayer.GetNormal(orientation, tilt);
          Coordinate2D end_pt = new Coordinate2D(0, 0);
          if (s > 0)
            //position each section evenly spaced along the diagonal
            var segments = new List<Segment>() as ICollection<Segment>;
            var part = GeometryEngine.Instance.GetSubCurve3D(
                diagonal, 0.0, s * spacing, AsRatioOrLength.AsRatio);
            part.GetAllSegments(ref segments);
            end_pt = segments.First().EndCoordinate;
            Name = $"Diagonal {s + 1}",
            VoxelPosition = new Coordinate3D(end_pt.X, end_pt.Y, volumeSize.Z),
            Normal = normal,
            IsVisible = true
    Update Section Orientation and Tilt
        foreach (var section in volume.GetSections())
          //set each normal to 45.0 orientation and tilt
          section.Normal = voxelLayer.GetNormal(45.0, 45.0);
          //apply the change
          volume.UpdateSection(section);
    Requirements
