ArcGIS.Desktop.Mapping Namespace / VoxelLayer Class / SetIsosurfaceContainerVisibility Method
Toggle visibility.
Example
    Sets the isosurface container visibility. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public void SetIsosurfaceContainerVisibility(
       bool isVisible
    Public Sub SetIsosurfaceContainerVisibility( _
       ByVal isVisible As Boolean _
    Parameters
    isVisible
    Toggle visibility.
    Exceptions
    ExceptionDescription
    This method or property must be called within the lambda passed to QueuedTask.Run
    Example
    Manipulate the Voxel Layer TOC Group
      //Toggle containers and visibility in the TOC
      await QueuedTask.Run(() =>
        voxelLayer.SetExpanded(!voxelLayer.IsExpanded);
        voxelLayer.SetVisibility(!voxelLayer.IsVisible);
        voxelLayer.SetIsosurfaceContainerExpanded(!voxelLayer.IsIsosurfaceContainerExpanded);
        voxelLayer.SetIsosurfaceContainerVisibility(!voxelLayer.IsIsosurfaceContainerVisible);
        voxelLayer.SetSliceContainerExpanded(voxelLayer.IsSliceContainerExpanded);
        voxelLayer.SetSliceContainerVisibility(!voxelLayer.IsSliceContainerVisible);
        voxelLayer.SetSectionContainerExpanded(!voxelLayer.IsSectionContainerExpanded);
        voxelLayer.SetSectionContainerVisibility(!voxelLayer.IsSectionContainerVisible);
        voxelLayer.SetLockedSectionContainerExpanded(!voxelLayer.IsLockedSectionContainerExpanded);
        voxelLayer.SetLockedSectionContainerVisibility(!voxelLayer.IsLockedSectionContainerVisible);
    Requirements
