ArcGIS.Desktop.Mapping Namespace / VoxelLayer Class / SetLockedSectionContainerVisibility Method
Toggle visibility.
Example
    Sets the locked section container visibility. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Sub SetLockedSectionContainerVisibility( _
       ByVal isVisible As Boolean _
    public void SetLockedSectionContainerVisibility(
       bool isVisible
    Parameters
    isVisible
    Toggle visibility.
    Exceptions
    ExceptionDescription
    This method or property must be called within the lambda passed to QueuedTask.Run
    Example
    Manipulate the Voxel Layer TOC Group
      //Toggle containers and visibility in the TOC
      // Note: call within QueuedTask.Run()
        voxelLayer.SetExpanded(!voxelLayer.IsExpanded);
        voxelLayer.SetVisibility(!voxelLayer.IsVisible);
        voxelLayer.SetIsosurfaceContainerExpanded(!voxelLayer.IsIsosurfaceContainerExpanded);
        voxelLayer.SetIsosurfaceContainerVisibility(!voxelLayer.IsIsosurfaceContainerVisible);
        voxelLayer.SetSliceContainerExpanded(voxelLayer.IsSliceContainerExpanded);
        voxelLayer.SetSliceContainerVisibility(!voxelLayer.IsSliceContainerVisible);
        voxelLayer.SetSectionContainerExpanded(!voxelLayer.IsSectionContainerExpanded);
        voxelLayer.SetSectionContainerVisibility(!voxelLayer.IsSectionContainerVisible);
        voxelLayer.SetLockedSectionContainerExpanded(!voxelLayer.IsLockedSectionContainerExpanded);
        voxelLayer.SetLockedSectionContainerVisibility(!voxelLayer.IsLockedSectionContainerVisible);
    Requirements
