public void SetSliceContainerExpanded( bool isExpanded )
Public Sub SetSliceContainerExpanded( _ ByVal isExpanded As Boolean _ )
Parameters
- isExpanded
- Toggle expanded.
| Exception | Description |
| ArcGIS.Core.CalledOnWrongThreadException | This method or property must be called within the lambda passed to QueuedTask.Run |
//Toggle containers and visibility in the TOC
await QueuedTask.Run(() =>
voxelLayer.SetExpanded(!voxelLayer.IsExpanded);
voxelLayer.SetVisibility(!voxelLayer.IsVisible);
voxelLayer.SetIsosurfaceContainerExpanded(!voxelLayer.IsIsosurfaceContainerExpanded);
voxelLayer.SetIsosurfaceContainerVisibility(!voxelLayer.IsIsosurfaceContainerVisible);
voxelLayer.SetSliceContainerExpanded(voxelLayer.IsSliceContainerExpanded);
voxelLayer.SetSliceContainerVisibility(!voxelLayer.IsSliceContainerVisible);
voxelLayer.SetSectionContainerExpanded(!voxelLayer.IsSectionContainerExpanded);
voxelLayer.SetSectionContainerVisibility(!voxelLayer.IsSectionContainerVisible);
voxelLayer.SetLockedSectionContainerExpanded(!voxelLayer.IsLockedSectionContainerExpanded);
voxelLayer.SetLockedSectionContainerVisibility(!voxelLayer.IsLockedSectionContainerVisible);
//Use the SelectedVariableProfile to get the slices currently in the TOC
//via its associated volume
var volume = voxelLayer.SelectedVariableProfile.Volume;
var slices = volume.GetSlices();
//Do something... e.g. make them visible
foreach (var slice in slices)
slice.IsVisible = true;
volume.UpdateSlice(slice);
//expand the slice container and make sure container visibility is true
voxelLayer.SetSliceContainerExpanded(true);
voxelLayer.SetSliceContainerVisibility(true);
if (voxelLayer.Visualization != VoxelVisualization.Volume)
voxelLayer.SetVisualization(VoxelVisualization.Volume);
//To stop the Voxel Exploration Dockpane activating use:
voxelLayer.AutoShowExploreDockPane = false;
//This is useful if u have your own dockpane currently activated...
var volumeSize = volume.GetVolumeSize();
//Orientation 90 degrees (West), Tilt 0.0 (vertical)
//Convert to a normal
var normal = voxelLayer.GetNormal(90, 0.0);
//Create the slice at the voxel mid-point. VoxelPosition
//is specified in voxel-space coordinates
//Create the slice on the respective volume
volume.CreateSlice(new SliceDefinition()
Name = "Middle Slice",
VoxelPosition = new Coordinate3D(volumeSize.X / 2, volumeSize.Y / 2, volumeSize.Z / 2),
Normal = normal,
IsVisible = true
//reset if needed...
voxelLayer.AutoShowExploreDockPane = true;
