ArcGIS.Desktop.Mapping Namespace / VoxelLayer Class / SetVisualization Method
The visualization mode to set
Example
    Sets the visualization mode. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public void SetVisualization(
       VoxelVisualization visualization
    Public Sub SetVisualization( _
       ByVal visualization As VoxelVisualization _
    Parameters
    visualization
    Exceptions
    ExceptionDescription
    This method or property must be called within the lambda passed to QueuedTask.Run
    Example
    Change the Voxel Visualization
      await QueuedTask.Run(() =>
        //Change the visualization to Volume
        //e.g. for creating slices
        voxelLayer.SetVisualization(VoxelVisualization.Volume);
        //Change the visualization to Surface
        //e.g. to create isosurfaces and sections
        voxelLayer.SetVisualization(VoxelVisualization.Surface);
    Check CanCreateIsoSurface
      //Visualization must be surface or CanCreateIsosurface will return
      //false
      if (voxelLayer.Visualization != VoxelVisualization.Surface)
      //Get the variable profile on which to create the iso surface
      var variable = voxelLayer.SelectedVariableProfile;
      //or use ...voxelLayer.GetVariableProfiles().First(....
      // o Visualization must be Surface
      // o Variable profile must be continuous
      // o Variable MaxNumberofIsoSurfaces must not have been reached...
      if (variable.CanCreateIsosurface)
        //Do the create
    Create Isosurface
          //Note: calling create if variable.CanCreateIsosurface == false
          //will trigger an InvalidOperationException
          //Specify a voxel value for the iso surface
          var min = variable.Statistics.MinimumValue;
          var max = variable.Statistics.MaximumValue;
          var mid = (max + min) / 2;
          //color range (i.e. values that are being rendered)
          var renderer = variable.Renderer as CIMVoxelStretchRenderer;
          var color_min = renderer.ColorRangeMin;
          var color_max = renderer.ColorRangeMax;
          //keep the surface within the current color range (or it
          //won't render)
          if (mid < color_min)
            mid = renderer.ColorRangeMin;
          else if (mid > color_max)
            mid = renderer.ColorRangeMax;
          //Create the iso surface
          var suffix = Math.Truncate(mid * 100) / 100;
          variable.CreateIsosurface(new IsosurfaceDefinition()
            Name = $"Surface {suffix}",
            Value = mid,
            IsVisible = true
    How to Change Value and Color on an Isosurface
        //Change the color of the first surface for the given profile
        var surface = variable.GetIsosurfaces().FirstOrDefault();
        if (surface != null)
          //Change the iso surface voxel value
          surface.Value = surface.Value * 0.9;
          //get a random color
          var count = new Random().Next(0, 100);
          var colors = ColorFactory.Instance.GenerateColorsFromColorRamp(
            ((CIMVoxelStretchRenderer)variable.Renderer).ColorRamp, count);
          var idx = new Random().Next(0, count - 1);
          surface.Color = colors[idx];
          //set the custom color flag true to lock the color
          //locking the color prevents it from being changed if the
          //renderer color range or color theme is updated
          surface.IsCustomColor = true;
          //update the surface
          variable.UpdateIsosurface(surface);
    Delete Isosurfaces
        //delete the last surface
        var last_surface = variable.GetIsosurfaces().LastOrDefault();
        if (last_surface != null)
          variable.DeleteIsosurface(last_surface);
        //delete all the surfaces
        foreach (var surface in variable.GetIsosurfaces())
          variable.DeleteIsosurface(surface);
        //Optional - set visualization back to Volume
        if (variable.GetIsosurfaces().Count() == 0)
    Create a Slice
        if (voxelLayer.Visualization != VoxelVisualization.Volume)
        voxelLayer.SetSliceContainerExpanded(true);
        voxelLayer.SetSliceContainerVisibility(true);
        //To stop the Voxel Exploration Dockpane activating use:
        voxelLayer.AutoShowExploreDockPane = false;
        //This is useful if u have your own dockpane currently activated...
        //Use the SelectedVariableProfile to get the slices currently in the TOC
        //via its associated volume
        var volume = voxelLayer.SelectedVariableProfile.Volume;
        var volumeSize = volume.GetVolumeSize();
        //Orientation 90 degrees (West), Tilt 0.0 (vertical)
        //Convert to a normal
        var normal = voxelLayer.GetNormal(90, 0.0);
        //Create the slice at the voxel mid-point. VoxelPosition
        //is specified in voxel-space coordinates
        //Create the slice on the respective volume
        volume.CreateSlice(new SliceDefinition()
          Name = "Middle Slice",
          VoxelPosition = new Coordinate3D(volumeSize.X / 2, volumeSize.Y / 2, volumeSize.Z / 2),
          Normal = normal,
          IsVisible = true
        //reset if needed...
        voxelLayer.AutoShowExploreDockPane = true;
    Change Tilt on a Slice
        //Normally, it would be set in your dockpane
        var slice = volume.GetSlices().First(s => s.Name == "Change Tilt Slice");
        (double orientation, double tilt) = voxelLayer.GetOrientationAndTilt(slice.Normal);
        //Convert orientation and tilt to a normal
        slice.Normal = voxelLayer.GetNormal(orientation, 45.0);
        volume.UpdateSlice(slice);
        //reset if needed...Normally this might be when your dockpane
        //was de-activated (ie "closed")
    Get the Current Collection of Sections
        voxelLayer.SetSectionContainerExpanded(true);
        voxelLayer.SetSectionContainerVisibility(true);
        //Use the SelectedVariableProfile to get the sections currently in the TOC
        var sections = volume.GetSections();
    Create a Section at the Voxel MidPoint
        //Create a section that cuts the volume in two on the vertical plane
        //Orientation 90 degrees (due West), Tilt 0 degrees
        //Position must be specified in voxel space
        volume.CreateSection(new SectionDefinition()
          Name = "Middle Section",
          Normal = normal,
          IsVisible = true
    Create a Horizontal Section
        //Create a section that cuts the volume in two on the horizontal plane
        //Or use normal (0, 0, 1) or (0, 0, -1)...
        var horz_section = SectionDefinition.CreateHorizontalSectionDefinition();
        horz_section.Name = "Horizontal Section";
        horz_section.IsVisible = true;
        horz_section.VoxelPosition = new Coordinate3D(volumeSize.X / 2, volumeSize.Y / 2, volumeSize.Z / 2);
        volume.CreateSection(horz_section);
    Create Sections in a Circle Pattern
        //180 degrees orientation is due South. 90 degrees orientation is due west.
        var south = 180.0;
        var num_sections = 12;
        var spacing = 1 / (double)num_sections;
        //Create a section every nth degree of orientation. Each section
        //bisects the middle of the voxel
        for (int s = 0; s < num_sections; s++)
          var orientation = south * (s * spacing);
            Name = $"Circle {s + 1}",
            Normal = voxelLayer.GetNormal(orientation, 0.0),
            IsVisible = true
    Create Sections that Bisect the Voxel
        //Make three Normals - each is a Unit Vector (x, y, z)
        var north_south = new Coordinate3D(1, 0, 0);
        var east_west = new Coordinate3D(0, 1, 0);
        var horizontal = new Coordinate3D(0, 0, 1);
        int n = 0;
        //The two verticals bisect the x,y plane. The horizontal normal bisects
        //the Z plane.
        foreach (var normal in new List<Coordinate3D> { north_south, east_west, horizontal })
            Name = $"Cross {++n}",
            Normal = normal,
            IsVisible = true
    Create Sections Diagonally across the Voxel
        //make a diagonal across the voxel
        var voxel_pos = new Coordinate3D(0, 0, volumeSize.Z);
        var voxel_pos_ur = new Coordinate3D(volumeSize.X, volumeSize.Y, volumeSize.Z);
        var lineBuilder = new LineBuilderEx(voxel_pos, voxel_pos_ur, null);
        var diagonal = PolylineBuilderEx.CreatePolyline(lineBuilder.ToSegment());
        //change as needed
        var orientation = 20.0; //(approx NNW)
        var tilt = -15.0;
        var normal = voxelLayer.GetNormal(orientation, tilt);
          Coordinate2D end_pt = new Coordinate2D(0, 0);
          if (s > 0)
            //position each section evenly spaced along the diagonal
            var segments = new List<Segment>() as ICollection<Segment>;
            var part = GeometryEngine.Instance.GetSubCurve3D(
                diagonal, 0.0, s * spacing, AsRatioOrLength.AsRatio);
            part.GetAllSegments(ref segments);
            end_pt = segments.First().EndCoordinate;
            Name = $"Diagonal {s + 1}",
            VoxelPosition = new Coordinate3D(end_pt.X, end_pt.Y, volumeSize.Z),
            Normal = normal,
            IsVisible = true
    Update Section Orientation and Tilt
        foreach (var section in volume.GetSections())
          //set each normal to 45.0 orientation and tilt
          section.Normal = voxelLayer.GetNormal(45.0, 45.0);
          //apply the change
          volume.UpdateSection(section);
    Update Section Visibility
        var sections = volume.GetSections().Where(s => !s.IsVisible);
        //Make them all visible
        foreach (var section in sections)
          //apply the change
    Delete Sections
          volume.DeleteSection(section);
        //optional...
    Get the Current Collection of Locked Sections
        voxelLayer.SetLockedSectionContainerExpanded(true);
        voxelLayer.SetLockedSectionContainerVisibility(true);
        var locked_sections = voxelLayer.GetLockedSections();
    Lock a Section/Create a Locked Section
      var mapView = MapView.Active;
        //get the selected section
        var section = mapView.GetSelectedSections().FirstOrDefault();
        if (section == null)
          section = volume.GetSections().FirstOrDefault();
          return;
        //Lock the section (Creates a locked section, deletes
        //the section)
        //if (voxelLayer.CanLockSection(section))
        //	voxelLayer.LockSection(section);
        if (volume.CanLockSection(section))
          volume.LockSection(section);
    Update Locked Section Visibility
        var locked_sections = voxelLayer.GetLockedSections().Where(ls => !ls.IsVisible);
        //Make them visible
        foreach (var locked_section in locked_sections)
          locked_section.IsVisible = true;
          //apply change
          voxelLayer.UpdateSection(locked_section);
    Unlock a Locked Section
        //get the selected locked section
        var locked_section = mapView.GetSelectedLockedSections().FirstOrDefault();
        if (locked_section == null)
          locked_section = voxelLayer.GetLockedSections().FirstOrDefault();
          return;
        //Unlock the locked section (Deletes the locked section, creates
        //a section)
        if (voxelLayer.CanUnlockSection(locked_section))
          voxelLayer.UnlockSection(locked_section);
    Requirements
