ArcGIS.Desktop.Mapping Namespace / VoxelLayer Class / UnlockSection Method
The definition of the section to unlock
Example
    Unlocks the specified section. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public void UnlockSection(
       LockedSectionDefinition lockedSectionDef
    Public Sub UnlockSection( _
       ByVal lockedSectionDef As LockedSectionDefinition _
    Parameters
    lockedSectionDef
    Exceptions
    ExceptionDescription
    This method or property must be called within the lambda passed to QueuedTask.Run
    Locked section is null
    Locked section not found in the collection of sections
    Section cannot be unlocked
    Remarks
    When a section is unlocked it is added back to the collection of (dynamic) sections.
    If a locked section cannot be unlocked then a System.ArgumentException is thrown. Refer to CanUnlockSection.
    Example
    Unlock a Locked Section
      var mapView = MapView.Active;
      await QueuedTask.Run(() =>
        if (voxelLayer.Visualization != VoxelVisualization.Surface)
          voxelLayer.SetVisualization(VoxelVisualization.Surface);
        voxelLayer.SetSectionContainerExpanded(true);
        voxelLayer.SetSectionContainerVisibility(true);
        voxelLayer.SetLockedSectionContainerExpanded(true);
        //get the selected locked section
        var locked_section = mapView.GetSelectedLockedSections().FirstOrDefault();
        if (locked_section == null)
          locked_section = voxelLayer.GetLockedSections().FirstOrDefault();
          return;
        //Unlock the locked section (Deletes the locked section, creates
        //a section)
        if (voxelLayer.CanUnlockSection(locked_section))
          voxelLayer.UnlockSection(locked_section);
    Requirements
