ArcGIS.Desktop.Mapping Namespace / VoxelLayer Class / IsDiffuseLightingEnabled Property
Example
    Gets whether diffuse lighting is enabled.
    Syntax
    public bool IsDiffuseLightingEnabled {get;}
    Public ReadOnly Property IsDiffuseLightingEnabled As Boolean
    Example
    Lighting Properties, Offset, Vertical Exaggeration
      await QueuedTask.Run(() =>
        //Offset
        var offset = voxelLayer.CartographicOffset;
        //apply an offset
        voxelLayer.SetCartographicOffset(offset + 100.0);
        //VerticalExaggeration
        var exaggeration = voxelLayer.VerticalExaggeration;
        //apply an exaggeration
        voxelLayer.SetVerticalExaggeration(exaggeration + 100.0);
        //Change the exaggeration mode to "ScaleZ" - corresponds to 'Z-coordinates'
        //on the Layer properties UI - must use the CIM
        var def = voxelLayer.GetDefinition() as CIMVoxelLayer;
        def.Layer3DProperties.ExaggerationMode = ExaggerationMode.ScaleZ;
        //can set vertical exaggeration via the CIM also
        //def.Layer3DProperties.VerticalExaggeration = exaggeration + 100.0;
        //apply the change
        voxelLayer.SetDefinition(def);
        //Diffuse Lighting
        if (!voxelLayer.IsDiffuseLightingEnabled)
          voxelLayer.SetDiffuseLightingEnabled(true);
        var diffuse = voxelLayer.DiffuseLighting;
        //set Diffuse lighting to a value between 0 and 1
        voxelLayer.SetDiffuseLighting(0.5); //50%
        //Specular Lighting
        if (!voxelLayer.IsSpecularLightingEnabled)
          voxelLayer.SetSpecularLightingEnabled(true);
        var specular = voxelLayer.SpecularLighting;
        voxelLayer.SetSpecularLighting(0.5); //50%
    Requirements
