ArcGIS.Desktop.Mapping Namespace / VoxelLayer Class / SelectedVariableProfile Property
Example
    Gets the currently selected variable profile.
    Syntax
    public VoxelVariableProfile SelectedVariableProfile {get;}
    Public ReadOnly Property SelectedVariableProfile As VoxelVariableProfile
    Example
    Get the Voxel Volume Dimensions
      var x_max = voxelLayer.GetVolumes().Max(v => v.GetVolumeSize().X);
      var y_max = voxelLayer.GetVolumes().Max(v => v.GetVolumeSize().Y);
      var z_max = voxelLayer.GetVolumes().Max(v => v.GetVolumeSize().Z);
      //Get the dimensions of just one volume
      var dimensions = voxelLayer.GetVolumes().FirstOrDefault();
      //Get the dimensions of the volume associated with the selected variable
      var dimensions2 = voxelLayer.SelectedVariableProfile.Volume.GetVolumeSize();
    Subscribe for Changes to a Voxel Layer
      MapMemberPropertiesChangedEvent.Subscribe((args) =>
        var voxel = args.MapMembers.OfType<VoxelLayer>().FirstOrDefault();
        if (voxel == null)
          return;
        //Anything changed on a voxel layer?
        if (args.EventHints.Any(hint => hint == MapMemberEventHint.VoxelSelectedVariable))
          //Voxel variable profile selection changed
          var changed_variable_name = voxel.SelectedVariableProfile.Variable;
          //TODO respond to change, use QueuedTask if needed
        else if (args.EventHints.Any(hint => hint == MapMemberEventHint.Renderer))
          //This can fire when a renderer becomes ready on a new layer; the selected variable profile
          //is changed; visualization is changed, etc.
          var renderer = voxel.SelectedVariableProfile.Renderer;
      VoxelAssetChangedEvent.Subscribe((args) =>
        //An asset changed on a voxel layer
        System.Diagnostics.Debug.WriteLine("");
        System.Diagnostics.Debug.WriteLine("VoxelAssetChangedEvent");
        System.Diagnostics.Debug.WriteLine($" AssetType: {args.AssetType}, ChangeType: {args.ChangeType}");
        if (args.ChangeType == VoxelAssetEventArgs.VoxelAssetChangeType.Remove)
          return;
        //Get "what"changed - add or update
        //eg IsoSurface
        VoxelLayer voxelLayer = null;
        if (args.AssetType == VoxelAssetEventArgs.VoxelAssetType.Isosurface)
          var surface = MapView.Active.GetSelectedIsosurfaces().FirstOrDefault();
          //there will only be one selected...
          if (surface != null)
            voxelLayer = surface.Layer;
        //Repeat for Slices, Sections, LockedSections...
        //GetSelectedSlices(), GetSelectedSections(), GetSelectedLockedSections();
    Get the Selected Variable Profile
      var sel_profile = voxelLayer.SelectedVariableProfile;
      //Get the variable profile name
      var profile_name = sel_profile.Variable;
    Change the Selected Variable Profile
      await QueuedTask.Run(() =>
        var profiles = voxelLayer.GetVariableProfiles();
        //Select any profile as long as it is not the current selected variable
        var not_selected = profiles.Where(p => p.Variable != sel_profile.Variable).ToList();
        if (not_selected.Count() > 0)
          voxelLayer.SetSelectedVariableProfile(not_selected.First());
    Access Stats and Color Range for a Stretch Renderer
      //Get the variable profile on which to access the data
      var variable = voxelLayer.SelectedVariableProfile;
      //or use ...voxelLayer.GetVariableProfiles()
      //Data range
      var min = variable.Statistics.MinimumValue;
      var max = variable.Statistics.MaximumValue;
      //Color range (Continuous only)
      double color_min, color_max;
      if (variable.DataType == VoxelVariableDataType.Continuous)
        var renderer = variable.Renderer as CIMVoxelStretchRenderer;
        color_min = renderer.ColorRangeMin;
        color_max = renderer.ColorRangeMax;
    Change Stretch Renderer Color Range
      //Typically, the default color range covers the most
      //commonly occurring voxel values. Usually, the data
      //range is much broader than the color range
        //Get the variable profile whose renderer will be changed
        //Check DataType
        if (variable.DataType != VoxelVariableDataType.Continuous)
          //must be continuous to have a Stretch Renderer...
        var color_min = renderer.ColorRangeMin;
        var color_max = renderer.ColorRangeMax;
        //increase range by 10% of the current difference
        var dif = (color_max - color_min) * 0.05;
        color_min -= dif;
        color_max += dif;
        //make sure we do not exceed data range
        if (color_min < variable.Statistics.MinimumValue)
          color_min = variable.Statistics.MinimumValue;
        if (color_max > variable.Statistics.MaximumValue)
          color_max = variable.Statistics.MaximumValue;
        //variable.Statistics.MinimumValue
        renderer.ColorRangeMin = color_min;
        renderer.ColorRangeMax = color_max;
        //apply changes
        variable.SetRenderer(renderer);
    Change The Visibility on a CIMVoxelColorUniqueValue class
        //Check DataType
        if (variable.DataType != VoxelVariableDataType.Discrete)
          return;//must be Discrete to have a UV Renderer...
        var renderer = variable.Renderer as CIMVoxelUniqueValueRenderer;
        //A CIMVoxelUniqueValueRenderer consists of a collection of
        //CIMVoxelColorUniqueValue classes - one per discrete value
        //in the associated variable profile value array
        //Get the first class
        var classes = renderer.Classes.ToList();
        var unique_value_class = classes.First();
        //Set its visibility off
        unique_value_class.Visible = false;
        //Apply the change to the renderer
        renderer.Classes = classes.ToArray();
        //apply the changes
    Check CanCreateIsoSurface
      //Visualization must be surface or CanCreateIsosurface will return
      //false
      if (voxelLayer.Visualization != VoxelVisualization.Surface)
        voxelLayer.SetVisualization(VoxelVisualization.Surface);
      //Get the variable profile on which to create the iso surface
      //or use ...voxelLayer.GetVariableProfiles().First(....
      // o Visualization must be Surface
      // o Variable profile must be continuous
      // o Variable MaxNumberofIsoSurfaces must not have been reached...
      if (variable.CanCreateIsosurface)
        //Do the create
    Create Isosurface
          //Note: calling create if variable.CanCreateIsosurface == false
          //will trigger an InvalidOperationException
          //Specify a voxel value for the iso surface
          var mid = (max + min) / 2;
          //color range (i.e. values that are being rendered)
          //keep the surface within the current color range (or it
          //won't render)
          if (mid < color_min)
            mid = renderer.ColorRangeMin;
          else if (mid > color_max)
            mid = renderer.ColorRangeMax;
          //Create the iso surface
          var suffix = Math.Truncate(mid * 100) / 100;
          variable.CreateIsosurface(new IsosurfaceDefinition()
            Name = $"Surface {suffix}",
            Value = mid,
            IsVisible = true
    How to Change Value and Color on an Isosurface
        //Change the color of the first surface for the given profile
        var surface = variable.GetIsosurfaces().FirstOrDefault();
          //Change the iso surface voxel value
          surface.Value = surface.Value * 0.9;
          //get a random color
          var count = new Random().Next(0, 100);
          var colors = ColorFactory.Instance.GenerateColorsFromColorRamp(
            ((CIMVoxelStretchRenderer)variable.Renderer).ColorRamp, count);
          var idx = new Random().Next(0, count - 1);
          surface.Color = colors[idx];
          //set the custom color flag true to lock the color
          //locking the color prevents it from being changed if the
          //renderer color range or color theme is updated
          surface.IsCustomColor = true;
          //update the surface
          variable.UpdateIsosurface(surface);
    Change Isourface Color Back to Default
        if (surface.IsCustomColor)
          surface.Color = variable.GetIsosurfaceColor((double)surface.Value);
          surface.IsCustomColor = false;
    Delete Isosurfaces
        //delete the last surface
        var last_surface = variable.GetIsosurfaces().LastOrDefault();
        if (last_surface != null)
          variable.DeleteIsosurface(last_surface);
        //delete all the surfaces
        foreach (var surface in variable.GetIsosurfaces())
          variable.DeleteIsosurface(surface);
        //Optional - set visualization back to Volume
        if (variable.GetIsosurfaces().Count() == 0)
          voxelLayer.SetVisualization(VoxelVisualization.Volume);
    Get the Collection of Slices
        //Use the SelectedVariableProfile to get the slices currently in the TOC
        //via its associated volume
        var volume = voxelLayer.SelectedVariableProfile.Volume;
        var slices = volume.GetSlices();
        //Do something... e.g. make them visible
        foreach (var slice in slices)
          slice.IsVisible = true;
          volume.UpdateSlice(slice);
        //expand the slice container and make sure container visibility is true
        voxelLayer.SetSliceContainerExpanded(true);
        voxelLayer.SetSliceContainerVisibility(true);
    Get a Slice
      var slice = volume.GetSlices().FirstOrDefault();
      var slice2 = volume.GetSlices().First(s => s.Id == my_slice_id);
    Create a Slice
        if (voxelLayer.Visualization != VoxelVisualization.Volume)
        //To stop the Voxel Exploration Dockpane activating use:
        voxelLayer.AutoShowExploreDockPane = false;
        //This is useful if u have your own dockpane currently activated...
        var volumeSize = volume.GetVolumeSize();
        //Orientation 90 degrees (West), Tilt 0.0 (vertical)
        //Convert to a normal
        var normal = voxelLayer.GetNormal(90, 0.0);
        //Create the slice at the voxel mid-point. VoxelPosition
        //is specified in voxel-space coordinates
        //Create the slice on the respective volume
        volume.CreateSlice(new SliceDefinition()
          Name = "Middle Slice",
          VoxelPosition = new Coordinate3D(volumeSize.X / 2, volumeSize.Y / 2, volumeSize.Z / 2),
          Normal = normal,
          IsVisible = true
        //reset if needed...
        voxelLayer.AutoShowExploreDockPane = true;
    Change Tilt on a Slice
        //Normally, it would be set in your dockpane
        var slice = volume.GetSlices().First(s => s.Name == "Change Tilt Slice");
        (double orientation, double tilt) = voxelLayer.GetOrientationAndTilt(slice.Normal);
        //Convert orientation and tilt to a normal
        slice.Normal = voxelLayer.GetNormal(orientation, 45.0);
        //reset if needed...Normally this might be when your dockpane
        //was de-activated (ie "closed")
    Delete Slice
        var last_slice = volume.GetSlices().LastOrDefault();
        if (last_slice != null)
          volume.DeleteSlice(last_slice);
        //Delete all slices
          volume.DeleteSlice(slice);
    Get a Section
      //Use the SelectedVariableProfile to get the sections currently in the TOC
      var section = volume.GetSections().FirstOrDefault();
      var section2 = volume.GetSections().First(sec => sec.ID == my_section_id);
    Get the Current Collection of Sections
        voxelLayer.SetSectionContainerExpanded(true);
        voxelLayer.SetSectionContainerVisibility(true);
        var sections = volume.GetSections();
    Create a Section at the Voxel MidPoint
        //Create a section that cuts the volume in two on the vertical plane
        //Orientation 90 degrees (due West), Tilt 0 degrees
        //Position must be specified in voxel space
        volume.CreateSection(new SectionDefinition()
          Name = "Middle Section",
          Normal = normal,
          IsVisible = true
    Create a Horizontal Section
        //Create a section that cuts the volume in two on the horizontal plane
        //Or use normal (0, 0, 1) or (0, 0, -1)...
        var horz_section = SectionDefinition.CreateHorizontalSectionDefinition();
        horz_section.Name = "Horizontal Section";
        horz_section.IsVisible = true;
        horz_section.VoxelPosition = new Coordinate3D(volumeSize.X / 2, volumeSize.Y / 2, volumeSize.Z / 2);
        volume.CreateSection(horz_section);
    Create Sections in a Circle Pattern
        //180 degrees orientation is due South. 90 degrees orientation is due west.
        var south = 180.0;
        var num_sections = 12;
        var spacing = 1 / (double)num_sections;
        //Create a section every nth degree of orientation. Each section
        //bisects the middle of the voxel
        for (int s = 0; s < num_sections; s++)
          var orientation = south * (s * spacing);
            Name = $"Circle {s + 1}",
            Normal = voxelLayer.GetNormal(orientation, 0.0),
            IsVisible = true
    Create Sections that Bisect the Voxel
        //Make three Normals - each is a Unit Vector (x, y, z)
        var north_south = new Coordinate3D(1, 0, 0);
        var east_west = new Coordinate3D(0, 1, 0);
        var horizontal = new Coordinate3D(0, 0, 1);
        int n = 0;
        //The two verticals bisect the x,y plane. The horizontal normal bisects
        //the Z plane.
        foreach (var normal in new List<Coordinate3D> { north_south, east_west, horizontal })
            Name = $"Cross {++n}",
            Normal = normal,
            IsVisible = true
    Create Sections Diagonally across the Voxel
        //make a diagonal across the voxel
        var voxel_pos = new Coordinate3D(0, 0, volumeSize.Z);
        var voxel_pos_ur = new Coordinate3D(volumeSize.X, volumeSize.Y, volumeSize.Z);
        var lineBuilder = new LineBuilderEx(voxel_pos, voxel_pos_ur, null);
        var diagonal = PolylineBuilderEx.CreatePolyline(lineBuilder.ToSegment());
        //change as needed
        var orientation = 20.0; //(approx NNW)
        var tilt = -15.0;
        var normal = voxelLayer.GetNormal(orientation, tilt);
          Coordinate2D end_pt = new Coordinate2D(0, 0);
          if (s > 0)
            //position each section evenly spaced along the diagonal
            var segments = new List<Segment>() as ICollection<Segment>;
            var part = GeometryEngine.Instance.GetSubCurve3D(
                diagonal, 0.0, s * spacing, AsRatioOrLength.AsRatio);
            part.GetAllSegments(ref segments);
            end_pt = segments.First().EndCoordinate;
            Name = $"Diagonal {s + 1}",
            VoxelPosition = new Coordinate3D(end_pt.X, end_pt.Y, volumeSize.Z),
            Normal = normal,
            IsVisible = true
    Update Section Orientation and Tilt
        foreach (var section in volume.GetSections())
          //set each normal to 45.0 orientation and tilt
          section.Normal = voxelLayer.GetNormal(45.0, 45.0);
          //apply the change
          volume.UpdateSection(section);
    Update Section Visibility
        var sections = volume.GetSections().Where(s => !s.IsVisible);
        //Make them all visible
        foreach (var section in sections)
          //apply the change
    Delete Sections
          volume.DeleteSection(section);
        //optional...
    Lock a Section/Create a Locked Section
      var mapView = MapView.Active;
        voxelLayer.SetLockedSectionContainerExpanded(true);
        voxelLayer.SetLockedSectionContainerVisibility(true);
        //get the selected section
        var section = mapView.GetSelectedSections().FirstOrDefault();
        if (section == null)
          return;
        //Lock the section (Creates a locked section, deletes
        //the section)
        //if (voxelLayer.CanLockSection(section))
        //	voxelLayer.LockSection(section);
        if (volume.CanLockSection(section))
          volume.LockSection(section);
    Requirements
