ArcGIS.Desktop.Mapping Namespace / VoxelVariableCreationParams Class
Members Example
    Represents an object used to represent a voxel layer variable.
    Syntax
    Public Class VoxelVariableCreationParams
    public class VoxelVariableCreationParams
    Remarks
    VoxelVariableCreationParams are retrieved from VoxelLayerCreationParams.Variables
    Example
    Create Voxel Layer
      // Note: call within QueuedTask.Run()
        //Must be a .NetCDF file for voxels
        var url = @"C:\MyData\AirQuality_Redlands.nc";
        var cim_connection = new CIMVoxelDataConnection()
          URI = url
        //Create a VoxelLayerCreationParams
        var createParams = VoxelLayerCreationParams.Create(cim_connection);
        createParams.IsVisible = true;
        //Can also just use the path directly...
        //var createParams = VoxelLayerCreationParams.Create(url);
        //Use VoxelLayerCreationParams to enumerate the variables within
        //the voxel
        var variables = createParams.Variables;
        foreach (var variable in variables)
          var line = $"{variable.Variable}: {variable.DataType}, " +
             $"{variable.Description}, {variable.IsDefault}, {variable.IsSelected}";
          System.Diagnostics.Debug.WriteLine(line);
        //Optional: set the default variable
        createParams.SetDefaultVariable(variables.Last());
        //Create the layer - map must be a local scene
        voxelLayer = LayerFactory.Instance.CreateLayer<VoxelLayer>(createParams, map);
    Inheritance Hierarchy
    System.Object
       ArcGIS.Desktop.Mapping.VoxelVariableCreationParams
    Requirements
