ArcGIS.Desktop.Mapping.Voxel Namespace / SliceDefinition Class
Members Example
    Represents the definition of a Slice. Refer to ArcGIS.Desktop.Mapping.VoxelLayer
    Object Model
    SliceDefinition ClassSliceDefinition ClassVoxelLayer ClassCoordinate3D StructureCoordinate3D Structure
    Syntax
    public class SliceDefinition
    Public Class SliceDefinition
    Remarks
    A slice is a plane that cuts the voxel volume. Use slices to define an area of interest within a voxel.
    Example
    Get the Collection of Slices
      await QueuedTask.Run(() =>
        //Use the SelectedVariableProfile to get the slices currently in the TOC
        //via its associated volume
        var volume = voxelLayer.SelectedVariableProfile.Volume;
        var slices = volume.GetSlices();
        //Do something... e.g. make them visible
        foreach (var slice in slices)
          slice.IsVisible = true;
          volume.UpdateSlice(slice);
        //expand the slice container and make sure container visibility is true
        voxelLayer.SetSliceContainerExpanded(true);
        voxelLayer.SetSliceContainerVisibility(true);
    Get a Slice
      var slice = volume.GetSlices().FirstOrDefault();
      var slice2 = volume.GetSlices().First(s => s.Id == my_slice_id);
    Get Selected Slice in TOC
      var mapView = MapView.Active;
        var slice = mapView?.GetSelectedSlices()?.FirstOrDefault();
        if (slice != null)
          //Do something with the slice
    Get Voxel Layer for the Selected Slice in TOC
        voxelLayer = null;
        if (slice != null)
          voxelLayer = slice.Layer;
          //TODO - use the layer
    Inheritance Hierarchy
    System.Object
       ArcGIS.Desktop.Mapping.Voxel.SliceDefinition
    Requirements
