public void CreateIsosurface( IsosurfaceDefinition isosurfaceDef )
Public Sub CreateIsosurface( _ ByVal isosurfaceDef As IsosurfaceDefinition _ )
Parameters
- isosurfaceDef
- The definition of the surface to create.
| Exception | Description |
| ArcGIS.Core.CalledOnWrongThreadException | This method or property must be called within the lambda passed to QueuedTask.Run. |
| System.InvalidOperationException | Isosurface cannot be added to this variable profile. |
| System.ArgumentException | Value cannot be null |
await QueuedTask.Run(() =>
//Visualization must be surface
if (voxelLayer.Visualization != VoxelVisualization.Surface)
voxelLayer.SetVisualization(VoxelVisualization.Surface);
//Get the variable profile on which to create the iso surface
var variable = voxelLayer.SelectedVariableProfile;
// o Visualization must be Surface
// o Variable profile must be continuous
// o Variable MaxNumberofIsoSurfaces must not have been reached...
if (variable.CanCreateIsosurface)
//Note: calling create if variable.CanCreateIsosurface == false
//will trigger an InvalidOperationException
//Specify a voxel value for the iso surface
var min = variable.Statistics.MinimumValue;
var max = variable.Statistics.MaximumValue;
var mid = (max + min) / 2;
//color range (i.e. values that are being rendered)
var renderer = variable.Renderer as CIMVoxelStretchRenderer;
var color_min = renderer.ColorRangeMin;
var color_max = renderer.ColorRangeMax;
//keep the surface within the current color range (or it
//won't render)
if (mid < color_min)
mid = renderer.ColorRangeMin;
else if (mid > color_max)
mid = renderer.ColorRangeMax;
//Create the iso surface
var suffix = Math.Truncate(mid * 100) / 100;
variable.CreateIsosurface(new IsosurfaceDefinition()
Name = $"Surface {suffix}",
Value = mid,
IsVisible = true
