public CIMVoxelRenderer Renderer {get;}
Public ReadOnly Property Renderer As CIMVoxelRenderer
MapMemberPropertiesChangedEvent.Subscribe((args) =>
var voxel = args.MapMembers.OfType<VoxelLayer>().FirstOrDefault();
if (voxel == null)
return;
//Anything changed on a voxel layer?
if (args.EventHints.Any(hint => hint == MapMemberEventHint.VoxelSelectedVariable))
//Voxel variable profile selection changed
var changed_variable_name = voxel.SelectedVariableProfile.Variable;
//TODO respond to change, use QueuedTask if needed
else if (args.EventHints.Any(hint => hint == MapMemberEventHint.Renderer))
//This can fire when a renderer becomes ready on a new layer; the selected variable profile
//is changed; visualization is changed, etc.
var renderer = voxel.SelectedVariableProfile.Renderer;
VoxelAssetChangedEvent.Subscribe((args) =>
//An asset changed on a voxel layer
System.Diagnostics.Debug.WriteLine("");
System.Diagnostics.Debug.WriteLine("VoxelAssetChangedEvent");
System.Diagnostics.Debug.WriteLine($" AssetType: {args.AssetType}, ChangeType: {args.ChangeType}");
if (args.ChangeType == VoxelAssetEventArgs.VoxelAssetChangeType.Remove)
return;
//Get "what"changed - add or update
//eg IsoSurface
VoxelLayer voxelLayer = null;
if (args.AssetType == VoxelAssetEventArgs.VoxelAssetType.Isosurface)
var surface = MapView.Active.GetSelectedIsosurfaces().FirstOrDefault();
//there will only be one selected...
if (surface != null)
voxelLayer = surface.Layer;
//Repeat for Slices, Sections, LockedSections...
//GetSelectedSlices(), GetSelectedSections(), GetSelectedLockedSections();
var variable = voxelLayer.GetVariableProfiles().First();
var renderer = variable.Renderer;
if (variable.DataType == VoxelVariableDataType.Continuous)
//Renderer will be stretch
var stretchRenderer = renderer as CIMVoxelStretchRenderer;
//access the renderer
else //VoxelVariableDataType.Discrete
//Renderer will be unique value
var uvr = renderer as CIMVoxelUniqueValueRenderer;
//Get the variable profile on which to access the data
var variable = voxelLayer.SelectedVariableProfile;
//or use ...voxelLayer.GetVariableProfiles()
//Data range
var min = variable.Statistics.MinimumValue;
var max = variable.Statistics.MaximumValue;
//Color range (Continuous only)
double color_min, color_max;
var renderer = variable.Renderer as CIMVoxelStretchRenderer;
color_min = renderer.ColorRangeMin;
color_max = renderer.ColorRangeMax;
//Typically, the default color range covers the most
//commonly occurring voxel values. Usually, the data
//range is much broader than the color range
await QueuedTask.Run(() =>
//Get the variable profile whose renderer will be changed
//Check DataType
if (variable.DataType != VoxelVariableDataType.Continuous)
//must be continuous to have a Stretch Renderer...
var color_min = renderer.ColorRangeMin;
var color_max = renderer.ColorRangeMax;
//increase range by 10% of the current difference
var dif = (color_max - color_min) * 0.05;
color_min -= dif;
color_max += dif;
//make sure we do not exceed data range
if (color_min < variable.Statistics.MinimumValue)
color_min = variable.Statistics.MinimumValue;
if (color_max > variable.Statistics.MaximumValue)
color_max = variable.Statistics.MaximumValue;
//variable.Statistics.MinimumValue
renderer.ColorRangeMin = color_min;
renderer.ColorRangeMax = color_max;
//apply changes
variable.SetRenderer(renderer);
//Check DataType
if (variable.DataType != VoxelVariableDataType.Discrete)
return;//must be Discrete to have a UV Renderer...
var renderer = variable.Renderer as CIMVoxelUniqueValueRenderer;
//A CIMVoxelUniqueValueRenderer consists of a collection of
//CIMVoxelColorUniqueValue classes - one per discrete value
//in the associated variable profile value array
//Get the first class
var classes = renderer.Classes.ToList();
var unique_value_class = classes.First();
//Set its visibility off
unique_value_class.Visible = false;
//Apply the change to the renderer
renderer.Classes = classes.ToArray();
//apply the changes
//Visualization must be surface
if (voxelLayer.Visualization != VoxelVisualization.Surface)
voxelLayer.SetVisualization(VoxelVisualization.Surface);
//Get the variable profile on which to create the iso surface
// o Visualization must be Surface
// o Variable profile must be continuous
// o Variable MaxNumberofIsoSurfaces must not have been reached...
if (variable.CanCreateIsosurface)
//Note: calling create if variable.CanCreateIsosurface == false
//will trigger an InvalidOperationException
//Specify a voxel value for the iso surface
var mid = (max + min) / 2;
//color range (i.e. values that are being rendered)
//keep the surface within the current color range (or it
//won't render)
if (mid < color_min)
mid = renderer.ColorRangeMin;
else if (mid > color_max)
mid = renderer.ColorRangeMax;
//Create the iso surface
var suffix = Math.Truncate(mid * 100) / 100;
variable.CreateIsosurface(new IsosurfaceDefinition()
Name = $"Surface {suffix}",
Value = mid,
IsVisible = true
//Change the color of the first surface for the given profile
var surface = variable.GetIsosurfaces().FirstOrDefault();
//Change the iso surface voxel value
surface.Value = surface.Value * 0.9;
//get a random color
var count = new Random().Next(0, 100);
var colors = ColorFactory.Instance.GenerateColorsFromColorRamp(
((CIMVoxelStretchRenderer)variable.Renderer).ColorRamp, count);
var idx = new Random().Next(0, count - 1);
surface.Color = colors[idx];
//set the custom color flag true to lock the color
//locking the color prevents it from being changed if the
//renderer color range or color theme is updated
surface.IsCustomColor = true;
//update the surface
variable.UpdateIsosurface(surface);
