public override SpatialReference GetSpatialReference()
Public Overrides Function GetSpatialReference() As SpatialReference
| Exception | Description |
| ArcGIS.Core.CalledOnWrongThreadException | This method or property must be called within the lambda passed to QueuedTask.Run |
// Check if a device is connected
bool isConnected = DeviceLocationService.Instance.IsDeviceConnected();
if (!isConnected)
return; // no device connected
// Get the current device location source
var src = DeviceLocationService.Instance.GetSource();
// Check if the source is a SerialPortDeviceLocationSource
//Set values for the SerialPortDeviceLocationSource
if (src is SerialPortDeviceLocationSource serialPortSrc)
var port = serialPortSrc.ComPort;
var antennaHeight = serialPortSrc.AntennaHeight;
var dataBits = serialPortSrc.DataBits;
var baudRate = serialPortSrc.BaudRate;
var parity = serialPortSrc.Parity;
var stopBits = serialPortSrc.StopBits;
var sr = await QueuedTask.Run(() =>
return serialPortSrc.GetSpatialReference();
//Get current device location properties being used.
var dlProps = DeviceLocationService.Instance.GetProperties();
var accuracy = dlProps.AccuracyThreshold;
